The alarm came on one time before and I took it to the dealer and he said it was water in fuel filter alarm. 50 hours later, and I did install new 10 micron recently and its on again, only in idle? How can I stop it and where is this filter located?
OK I found the location, has 2 bolts holding the canister on, has a wire, water detector? going in the bottom, one line going in each side. How do I get the plastic canister off to dump and how do you re-set the alarm? Help Please I need to go cobia fishing
Thanks in advance for any help.
