I have a 2002 Yamaha 90 2 stroke motor. Last weekend I was waiting to put my boat on the trailer. I turned off the motor and when I went to start it nothing! I had to pull start it. I have checked the following. One side of the relay has power. If I jump acroos the relay the engine cranks. I have check the continuity of the kill switch. And there is 12 volts constant after the fuse on the red wire that goes to the left side of the starter coil. I did not check the brown wire. What should I do?/?
Yamaha 90 2 stroke motor 2002 won't start
