One head cool
  • One head cool
    On my twin 89 200s, after running a good while one head is cool and you can hold you hand on it and the other 3 are good and hot. Thermostats are working fine.
    What could cause one head to run cool? I was thinking low compression but motor runs smooth. Will do a compression test today anyway.....
    maybe that cylinder is not firing, did you test stats in heated water to see what temp they open and closed?
    Use a temp gun to look at all parts of heads and post the readings
      I put new stats in and no difference. When I tested with my hand I put it on the top of the head. Yeah, maybe that cylinder is not firing and thus no heat. Sure runs smooth to be running on 5 cylinders, though.....
      Heat gun is good idea....should be able to isolate which cylinder.
      Could poppet valve stuck make one bank run cool?
        Did compression test and all 12 were 115-120. Forgot my heatgun.....
        I did notice that the cooler running motor's plugs were not the nice ****en brown (insulator) of the hotter runner. They were black and oily.
        What would make it run too cool other than themostats?
