2007 Yamaha 4HP coolant leak
  • 2007 Yamaha 4HP coolant leak
    2007 F4MSH has about 100 hours 99% slow *****ing speed.
    Ran up in tank today readying for fishing .
    Halfway down to the lower unit the shift rod goes into a plate through a rubber seal which has a small chip out of it. A tiny bit of hot water is leaking/bubbling out.
    Just above this is a 1/4" thick rubber seperator between the lower unit sections.
    There is a slight bit of movement here with sideways pressure on lower unit.
    Do I have a problem or can I run like this?
    Ran fine with good telltale stream. Minnesota freshwater use.
    Help will be sincerely appreciated.
    Common to see water come out around lower housing, as water exits engine it goes through mid section and out through prop.
