OX66 250hp Over heat at low RPM
  • OX66 250hp Over heat at low RPM
    2000 ox66 250s
    Only seems to over heat at low rpm, have good water coming out. Water pumps, Thermostats are new.
    Is this a Poppet valve issue?
    where do I find a diagram of the poppet valve?
    Thanks,
    Dennis
    thats what it sounds like,check the parts for that motor and it will show you where it is
      Do you know what listing its under? started looking and didnt see it in the explosion charts
        Yea, it's there. Probably around the power head section. Suggest getting the new style valve, gasket, and grommet. Be real carefull replacing the grommet. Sometimes tends to pop inside water jacket (been there). It's retrievable but a bitch to do. Need to remove the cable connectors from the bottom of the ECU to get to the job.
          It's number 19 in this link, 2000 SX250TXRY Yamaha Outboard CYLINDER CRANKCASE 2 Diagram and Parts
            Thanks Guys..appreciate the help!
