O.K., so the worry-wart here notices some small cracks in my trim ram wiper seals, no leaks or problems...but are these small cracks in the wipers anything to give me trouble later or should I see about replacing them sooner? Motor is 1999 Yamaha 90C.
Robert I thought you had a service manual, does it not tell you that?
To tell the truth I have not looked at it to see, but I am fairly sure that is all you need to do
If the cracks let stuff through to get to seals it could cause seal and scoring problems
Mr. Graham is asking a question instead of answering one?? I would buy the proper tool to remove the caps. Mine are torqued to about 95 lbs. Need a dental pick to get the seals out of the cap. If you're in there you should replace the orings and backup rings on the pistons & flush the oil.1999 Grady Sailfish SX225 OX66
Originally posted by Tucker View PostMr. Graham is asking a question instead of answering one?? I would buy the proper tool to remove the caps. Mine are torqued to about 95 lbs. Need a dental pick to get the seals out of the cap. If you're in there you should replace the orings and backup rings on the pistons & flush the oil.
That's the spec for the SX225's. Yours is probably much lower. The point is, guys will take a punch and hammer and try to remove the caps. Miss and ding the trim rods and they'll leak. The Yamaha tool works perfectly.1999 Grady Sailfish SX225 OX66
ÂÂÂÂÂ
