Hello,
I have a Yamaha 130 and the oil injection system has been disabled for 8 years and and the motor has been running fine. Recently a low oil alarm started to go off. The oil tank on the motor is 3/4 full and the float switch seems to operate correctly.
I'm confident the motor is not overheating because:
-I just replaced the water pump and thermostats
-The block is cool to the touch
-The Tach flashes with an Oil Alarm indicator
I unplugged the blue and red wire going into the Oil Sensor and noticed when I touch that wire to a positive power source the alarm stops. I touched it to the positive wire coming from my battery. I thought an easy solution would be to just wire this blue/red wire to the positive power coming from the battery but when I do that my gauges power up, even with the key switch off, so this is not a good solution.
This is my basic question: Is there an easy way to disable the low oil alarm since in my case it is a false alarm??
Thanks!
Thanks!
