Trying to locate the pressure control valve on 2006 F250 TUR . I’ve been searching through all diagram didn’t find it can someone tell me where is located at?
2006 Yamaha F250 PCV
Number 8 in this link 2006 and Later 4-stroke F250TUR Yamaha Outboard UPPER CASING Diagram and Parts
2006 f250 PCV
Thanks that was very helpful. One more questions on this PCV .Is there any way to check to see if this parts are bad? Also can it be clean? Cause I’m having issue with overheating at high rpm around 3000 & up. Spoke to one of tech works at Yamaha he told me that if this parts goes bad it normally overheat at low rpm
ÂÂÂÂ
