anyone on here have a diagram of replacing a water pump on a 2001 50 hp four stroke?
water pump
Sounds like you need to pick up a factory service manual or look through youtube to see if you can something on your motor.
If you look up the parts break down of your motor it will have a breakdown of where all parts are located in relation of each other
Check: Yamaha Outboard Maintenance Tips, for instructions with photos for water pumps and other items...may prove helpful. Good Luck!
ÂÂÂÂÂÂÂÂÂÂ
