VST will not go back together
  • VST will not go back together
    2003 150 DX150TLRB
    I replaced the fuel filter in the VST tank this weekend. However, when I reassembled the VST tank, the tank will not fit correctly on the pump side. It has about a ¼ to ½ inch separation. I then removed the plate 2 (Yamaha part # 66K-13844-00-00) and the tank will go together fine. I have looked at the plate and it does not seem to be bent or warped. There is also a damper pump that fits inside plate 2. Could the damper pump be swollen and not fitting correctly?
    Make sure oring on top of pump is in correct position and filter is installed correctly.
