I need to find out where the best place is to check on tools,I am needing to replace the gearcase seals on my yamaha. ?? or would I be better off paying my mechanic $300 to do this
2000 Yamaha VX225TLRY
Tools are a special order item and not listed on web site, you can call boats.net at 877-408-1499 to order the special tools.
225 vmax
well I fixed my outboard,didn't need any special tools. I replaced the bearing hub with a new bearing the hub and 2 seals. Then I did a pressure check on it,I found air coming out of the prop shaft seal. So me and a buddy of mine replaced both the seals and it is running like a dream.
Thanks for the help and I want to thank you all very much.
ÂÂÂÂÂ
