Hi,
So I've got a 21' aluminum jet boat with a 175 HPDI. I had one blue top optima group 27 (800cca I believe) installed into the bow storage of the boat. From there, the riggers ran AWG4 leads from the battery back to 2 separate 3/8" posts. This run is roughly 18-19 feet. The leads from the main motor were coiled up instead of being shortened (is this common install practice?) and run to the posts. Then all my electrical is also run to the posts. I do not have a large electrical load, (bilge, , washdown, 4 speaker stereo, 2 lights, 2 downriggers, Lowrance HDS8) and they are never all on at the same time. In addition I have a T9.9 kicker that provides a charge the entire time I'm *****ing, etc. My problem is that when I have my Lowrance on and go to start the main 175 motor, I get a low voltage and the lowrance resets. I went all thru Lowrance and there is no fix from their end.
I was thinking of shortening the battery leads from the motor (removing roughly 4 feet) and replacing the leads from the bow. I was hoping AWG2 would do the trick but wanted some advice. AWG0? AWG 1/0?
thanks
sean
thanks
sean
