98 150 no spark???
  • 98 150 no spark???
    I have a C150TLRW that I dont have any spark I tried unplugging the harnes??
    Also can anyone tell me if any of the parts off my friends blown up L150ETXD are interchangable, especially the ignition parts?? thank you
    when you unplugged 10 pin main did you turn over remotely ? brown wire @ start relay ?
      yes. i used a jumber between the batery terminal and the brown wire?
        Then need to test voltage output of charge coil, pulsor coil and CDI output with a peak reading voltmeter.
        The C150 will probably use different ignition than the 2005 L150.
