I have a 93 Yamaha PROV150LD outboard that is not pumping oil from the boat tank to the tank on the side of the motor. I had a tilt switch short my relay earlier and I read that the tilt could cause a problem with this. I need to figure out if the pump is bad or if it is something else. Also if the up
P is bad does anyone know how to change it out.
Thanks Bert
Thanks Bert
