Can a Tilt and Trim Switch be installed in a Yamaha 1998 90hp CTLRW in the lower top cowling?? I only have the one at the controls. A separate one at the motor would really be helpful. Thanks
Tilt & Trim Switch
Originally posted by boats.net View PostYou can by by connecting switch to small green(down wire) and small blue(up wire) at trim relay.
OK, What type of switch woulf I use and being that the lower half of the cowling doesn't have a hole to recieve the switch, do you have any suggestions on where and how to install it?
Probably have to use a momentary 3 way toggle switch with water proof boot.
ÂÂÂÂÂÂÂÂ
