Digital Gauges to Analog Gauges
  • Digital Gauges to Analog Gauges
    I have a 1993 200 that has digital gauges that are unreadable. I was wondering if I can replace them with analog gauges.
    Bob
    Yes, if you use the analog tach with oil lights then you may need wire adapters to connect the gauge to oil wire harness, the gauges and harness were changed in 1994. If you get the trim gauge use the 3 wire gauge and adapter may be needed.
