Hello,
i had used the search but didn't find the Answer: I hav a Yamaha F70 (buyed 2011) and two digital Instruments. One of these ist the "tach" Instrument with a lable on the backside with the code "6Y8T-11" on it. The second one is the "Speed / Fuel" gauge with the code "6Y80-11" on the backside lable. I want to connect a "triducer" to display the Depth (sonar), ambient water temperature and the speed (waterspeed) on these gauges.
Is this possible?
If yes, is the "6Y8-83688-01-00 TRANSOM SENSOR" the right product?
I only have one hub biult in, the Distance between Transom and hub is about 5 meters, can i make the Connections myself, or do i need a cable between hub and triducer? If yes, which cable is to use?
Thank you
BNE
Is this possible?
Thank you
BNE
