fuel management meter
  • fuel management meter
    I have installed new dual meter and sending units and new wire harness but I can only get meter to show fuel usage for one motor.And the meter doesnt toggle between the two motors. Any ideas on what I need to do?
    Recheck wiring, inspect connections at sensors and gauge, check green tach signal wires are connected and make sure FMM is using same ground source as tach and speedo.
