Yami 30HP Tiller Reverse problems?
  • Yami 30HP Tiller Reverse problems?
    I have a 30 HP 2 stroke tiller engine. I used the boat on Sunday and had no issues w/ the reverse. However, on the way back to the ramp, I ran too shallow during a slow idle causing the motor to stop. I poled out of the shallow and started it and ran forward to the ramp w/ no problem.
    After flushing the motor, (it was off) I noticed that the lever would not go into revese. I couldn't push it back into reverse at all. No issues w/ forward and neutral. Somehow I thought to turn the prop. After turning the prop, the lever went into reverse. However I noticed that sometimes, the lever would go easily into reverse, other times it wouldn't at all unless I slightly turned the prop.
    I haven't had a chance to run this in water to see if I would have problems getting it into reverse while in use. What would cause this issue?
    Thanks.
    the motor needs to be running so that the shaft is turning otherwise you have to turn the prop to get it all to mesh up properly
