I have twin 2001 OX-66 200Hp Yammies, which run great. The port engine uses 50% more oil than the stbd. The stbd engine uses oil at a rate of about 50:1 so the port is over injecting. What's the procedure for reducing oil flow and is there a limit so that it doesn't under inject?
2. I had the head torqued after about 50 hours, but not since (now about 300 hrs). Is it necessasry/desirable to retorque them?
