I have a grizzly 1754 with a 25hp 2010 yamaha 4stroke.It has a 9 7/8 x 10 1/2 3 blade prop on it now. I want to go to a 4 blade prop and am not sure which would be better. Runs about 23 mph gps numbers and am pleased with numbers. Don't really want to loose any speed if possible.
4 blade solas prop
Usually need to drop 1 inch pitch when going from 3 blade to 4 blade props as long as they are both same material, 2 inches if going from alum to SS prop. But generally the 4 blade has less top speed than the 3 blade props.
banged uo
banged up the factory prop on some rocks. Gonna keep the factory prop for the rocks. Not bab but bad enough.Was gonna get another one for the lakes. Thought about the 4 blade, but sounds like I need to stay with the 3 blade. What would be the replacement if I went to stainless?Last edited by redhorse99; 01-14-2012, 11:00 AM.
ÂÂÂÂÂÂÂÂ
