Yamaha VX200TLRA specs?
  • Yamaha VX200TLRA specs?
    I have a 2002 yamaha vx200tlra I would like to know what the compression spec is what is good for this engine to have after doin a compression test
    Compression should be even or no more than 10 percent difference in cylinders.
      Does about 95 give or take one or two psi sound ok for all cylinders
        If they are all within 2 psi that is ok. Run shock treatment of Yamaha Ring Free through it.
