was trying to bleed fuel line when brass drain plug broke, how do i get it out?
i bought a replacement from a yamaha dealer today.
please help.
Get an "Easy out" kit, drill the broke drain plug carefully in the center (make sure all the fuel vapors are gone for safety) and gently tap in the easy out. Turn it counter clockwise and it should remove your broken plug.
Make sure you flush out any filings/etc. Kits are available at most hardware stores, Sears, etc...
