Today my motor was tilted all the way in the up position and stuck there. It will not go down. I have read other posts where folks talked about relays etc.
In my case, the motor does run when pushing down or up. I honestly believe there is no fluid in it. I unscrewed the hex screw on the right (the reservoir?) and didn't see any.
When I buy hydraulic fluid, is there a specific marine grade hydraulic fluid or when any type work? If I fill it properly, should it start working?
I appreciate any help you can provide.
