Tilt Trim Motor
  • Tilt Trim Motor
    I'm about to replace the tilt trim motor for a Yamaha F60 2002 model. I spilled some fluid as I took the original motor out. What fluid should I buy and how much should I put in. The Tilt rod is now at the near maximum extended position. Thanks
    Use Yamaha Power Trim fluid or Dextron II ATF.
