Ive got a 1998 200hp outboard and it stalls out when coming in to dock , it will start again but stalls after a couple of seconds . It runs great from cold start but struggles to start and idle once its warmed up , any ideas ?
200hp yamaha
Do you have a water separator. If so change it if you do. It sounds like the gas is failing when you are running. You all so could have a loose hose too.
Make shure that all of gas line are tight. All so do you have a primmer ball the valve in the do go bad so you do need to change them out.
ÂÂÂ
