winterizing question 90hp 4 stroke
  • winterizing question 90hp 4 stroke
    in order to drain all water from motor, could i blow air thru the garden hose connector ? will this remove all the water that might freeze during the winter ? if not what else must I do ?
    Thanx
    Just tilting motor down in down position the water will drain out of engine block.
      thank-you
      bill
