Anyone have any experience with removal and replacing a power head on a Yamaha 200HP HPDI ? I have a bad knoc, motor has 1197 hours on it. Compression cold varies between 68 - 90lbs per hole.
Took it to a certified Yamaha mechanic and after 1 1/2hrs and listening to the motor he thought I might have a piece of piston broken off or perhaps a rod bearing bad. To tear down the motor to fully diognose would cost a ton; he thought I should look at getting a new 4 stroke or a new power head. He said the powerhead cost was usually about half the price of a new motor.
My question is, how difficult is it to replace the powerhead? One of my crew members is a professional deisel mechanic but he is apprehensive about taking on the project because he is affraid of the special tool issue and just not knowing what is involved.
Another question is how many hours is a normal life on a HPDI motor with good maintanence? If I replace the powerhead will the lower unit become a problem in the near future?
Thanks In Advance for any advice,
LadyE
LadyE
