My motor on the tilt crapped out last week while fishing, was lucky to get it on the trailer and up the ramp (motor was down). Tried to use the manual override and the screw has ceased. (got lucky with some banging on the screw with a screwdriver and hammer, motor worked just enough to get up) Tech says to just leave it alone as it could possible shear off and the oring melting while trying to free it. I'm not too comfortable with that suggestion. what happens if the new motor quits ?? I then can't get the motor up for trailering and I'm screwed. whats the worst case senario if that happens ? will I need a knew hydraulic system ?
I need the peace of mind knowing I can get the outboard up with or without the motor(tilt) working. otherwise fishing won't be so peaceful.
any advise would be greatly appreciated
Thanx
Thanx
