Starter will not engage when I turn the key after cranking on it several times to get the fuel to the pistons, BUT when I jump the solenoid it engages just fine. Anyone no why? Is there a reset button somewhere?
Here a list of what I changed:
Battery Cables are New
Good Connections
Solenoid New
Fuel from the solenoid good not bown
Also I cleaned the carbs with Carb Cleaner over night and reinstalled correctly but motor will not run at idle. Anyone know why?
Here things I changed:
Carbs are clean and sealed tight.
fresh fuel
good oil
spark plugs are not new but give spark
Good Connections
Solenoid New
fresh fuel
good oil
