Two part question here.
Just replaced twin '92 200's with 2005 HPDI 200's. Controls and gauges the same. Dealer said that there is no way to make the trim indicator work on the older digital gauges with the newer motors. Said I had to buy all new gauges. I decided to wait and see if there was a work around since everything else works fine. Is there?
Also- After install the trim/tilt switch on the top of the binnacle 704 only works intermittently for trimming/tilting both engines UP. It always works for trim/tilt down, and the individual up down for each motor on the 704 work fine. Is this a switch problem or a loose connection somewhere?
Thanks for your help
