2002 Yamaha 4 stroke 225hp Audible Alarm
  • 2002 Yamaha 4 stroke 225hp Audible Alarm
    Hello All:
    248 operating hours on engine. After about 5 minutes in low water (3-4') idling in forward at slightly less then wake speed the audible alarm sounds.
    The engines runs fine. I typically shut the engine off and start up again without incident. No gauges for Oil pressure or water temp, just silly little lights. When the alarm goes off neither light appears to light up.
    Water pees out, but not a fast stream,more like a slow steady griple.
    The oil level is perfect. Is my problem the pump impeller, thermostats etc?
    Any other ideas?
