so I put in a tacho on my 2005 model 50hp yamaha its a tiller steer but I accidently pulled out the choke wire from the sealed harness
on the key side, now the engine takes bloody forever to start even when fully primed, so the million dollar question is what color is the choke wire on the engine side of the harness as the colors do not match up, I can see a blue wire coming from the choke behind the airbox but that goes up to the top back part of the head and joins with a yellow wire into a electrical component. I just want to bridge a wire over from the key side to the correct wire on the engine side so the choke will activate but cant work out which one? as I said the harness is sealed up so I have to cut through. can anyone help please ? thankyou Michael
