Hi there, I have a 1992 30hp (30MSHQ) that I rebuilt the lower unit that was seized. It's come back nicely but I don't seem to have a neutral...when shift lever is in 'neutral' the prop sins forward. When in forward it is the same. When I put it in reverse it slowly stops spinning and goes into reverse. The top end thinks it's in 'neutral' when I start it, but the prop is definetly spinning forward under power. did I miss a part or adjustment....thanks
1992 30hp shifter/gear problems
Hi Robert, i have a similar issue, wonder if you an help> no intent to take over thread> My reverse gear pops out and bangs away at the dogs when applying throtle. When i am adjusting the linkage for finding nuetral, should the be no noise as I spin the prop. i get a faint ticking. 2009 yammy 25hp 2 stroke.
Thanks in advance.
ÂÂÂÂÂ
