Remove Yamaha prop shaft
I'm new @ this posting procedure. So here goes.
225 Yamaha 1992. Lower unit, have retaining nut & keeper ring off housing.
How do I pull gears out ?
Can I pull on prop shaft or do you have to remove just bearing housing first ?
Sequence for disassembly ?
What about shift linkage ?
How much heat, assembly is really seized in lower unit.
Lost reverse & shavings on drain plug. Neutral & Forward work.
