I have a 2000 LX250TXRY outboard. I have a had a problem with the overheat buzzer/rpm limiter going off intermittently at low speeds. In observation of my engine, it continues to run fine, and pumping water good.
However, just recently it has started at higher speeds, but when i shutdown it resets but come back later.
I suspect a defective temp sensor, however, when looking at part diagrams for a replace I see two parts, and looking for some guidance on which one to change.
There is a thermo sensor assembly, and a thermo switch assembly.
Can someone tell me which one I need to order?
Again, I suspect the sensor due to engine running fine until buzzer activates. At least its a good place to start, but want to get right parts.
thanks in advance
Dave
thanks in advance
Dave
