4hp sticky throttle
  • 4hp sticky throttle
    I have 2008 4. Stroke 4hp, the throttle sticks in the open position , if you lift up the tiller you can see a wire/ rope the goes from the hand throttle to the engine, it winds up but does not unwind, what can i spray on it, wd40?
    Check your throttle friction screw that it's not too tight, then spray everything with WD-40 or similar until it frees up. Good Luck!
