After reading all the info on the corrosion problems. I am hoping that I don't have that problem and it is just a thermostat. Are there any tips I should be aware of when replacing these.
Being a virgin when it comes to working on these motors how do I tell if something went wrong with the water pump? I replaced the impeller a few months ago when it was out of the water. When I use the flushing connection I see water coming thru all the obvious ports, but there is a stream coming from the area where 2 bolts connect the lower unit to the upper. Since this happens on both sides is this normal?
