fault codes for f50 2011?
  • fault codes for f50 2011?
    Hi everybody¡
    I just got a f50. I´ve installated in my boat and when i started, the 6Y8 Tach showed a engine trouble warning with the 28 code. Someone has the fault codes list for the f50 2011? Also, the tach doesn´t show the right trim angle, always shows the maximum angle.
    Code 28 is incorrect neutral switch signal.
    Check the "Trim Set" function in Tach to reset trim gauge.
