Changed from factory prop size 15 and five eighths X 12 (which *****ed about 3mph) to new prop size 12 and one quarter X 9 (part 663-45956-01-EL) which I ordered form boats.net in order to slow down the *****ing speed. Outboard is a 2011 40HP 4 stroke with fuel injection. New prop slows boat to less than 3 mph, which is ideal, but causes the motor to vibrate and shake too much at closed throttle. Vibration will only stop when throttle is advanced to about 3 mph or greater which was not an improvement on the orginal prop. How can I get the new prop to run at idle speed without causing the motor to run so rough? Raising or lowering the motor with the trim switch does not help.
Prop question
