This engine is an '05 50HP TLR two-stroke.
I just need to verify: which way should I turn the air-mixture adjustment screws?
Which way is more lean, and which way is more rich?
Different sources all say different things.
Is there any trick to balance the mixture across all three carborators? I see no way to hook up a vacuum guage in order to check...
Thank you,
Metric
Thank you,
Metric
