I have a question pertaining to the Pressure control valve on my motor.
I ordered P/N # 6G5-12416-00-00 off website.
I received P/N # 60H-12416-00.
The pressure control valve off my motor does not look like what I received. My control valve has 2 cross ends on it. one is 1/2 inch long that goes into the the compression spring. The other end is the same as new one that goes into the grommet. Do I have the correct replacement and if so what end do I put into the grommet. The cross end or the button end without any thing to line up the spring on that end. Thanks in advance for replies.
