I've recently noticed more smoke than normal at idle and sheen on the water. So I did some research on the symptoms and found that its more than likely the low pressure fuel pumps (3) on the 250. When I did the replacement on the lp pumps I noticed there was oil leaking from the intake silencer. I've run the motor for a few hours after after replacing the lp pumps, it was windy so hard to tell if the smoking improved but I noticed the oil is still leaking. I did have the motor trimmed up for transport. Not sure what is causing this?
Oil leaking from intake silencer ox66
I believe a little oilly premix in the silencer is typical of most 2-strokes. They spit a bit with throttle changes. That smoke could be several things including the LP fuel pumps. Did you confirm that they were leaking?1999 Grady Sailfish SX225 OX66
ÂÂÂÂ
