On a previous post you stated fuel pressure on 2001 SX250 should be at 35psi. and hold 25psi with key off....I have 38 psi with engine running. With key off drops to 0 psi. What is the cause or what should I be looking for. Also, is there anything other than faulty low pressure pumps that would cause the VST to run dry ?
