Can anyone tell me where i can get hold of some seafoam in Australia, Tasmania. or something similar No one seems to of heard of it down here. This is regarding yamaha post looses power. Ken has given me some ideas to try and he suggested Seafoam to see if it makes a difference b4 sending it off and getting the carbys checked I have tried Pyrol injector cleaner to the fuel but hasnt seemed to done anything for me as seafoam doesnt run thru your tank?
Sea foam-shock treatment
You don't have to strip the carburator down to all it's small pieces. I watched my mechanic clean my jets with some wire he poked into the two jets. Removing the carburetor on my engine involved two main mounting bolts and two screws for a device that sits atop the carburetor. Pull the fuel feed hose off. Unhook the throtle linkage. The whole thing came off real easy. Once off, on my carb you take off four screws for the main chamber which reveals the jets and the float bowl. Just gently push the float away and clean any crud at the bottom of the bowl. Poke a fine wire gently into the jets to unblock them. Re-assemble and you are set to go.
It's actually easier than it sounds. Just be carefull not to drop any parts overboard, if you work while the engine is in the water.
ÂÂ
