I have taken the boat in to the shop. Im starting to wounder about mechanics. 300 to 1 guy to rebuild lower carb and i rebuilt upper carb. Although I have had rebuilt both carbs and checked air leaks and so on. Couldn't get it to go right. Shop calls and says they can't figure out the cdi unit or the coil packs with the omh meter. Said I had no spark to two plugs and changed around a wire on something and got all 4 to fire then put wires back the right way and still all 4 fire. Thier telling me it could be the cdi unit or pulsar coils. Sounds like a bad ground wire to me, OR could it be a bad cdi unit or coils if all are working now? cost 300 just for them to tell me this. is this common to spend 5 hours checking on spark and timning? And still not besure if its that or not. Please help on this matter. I did disconnect the white wire on the cdi box and had fire. so whats next change both out?
Thanks K.C
Thanks K.C
