Thanks for your time at reviewing this post.Recently purchased a 2004 Ranger with a 2004 3.1L VX200LTRC.It blue smokes when you start it like an older 2 stroke.I ran a compression check before I purchased the boat.The compression was 120#-125# on all 6 cylinders.I assumed this was okay.Is the smoking normal or could something be wrong with the oil injection? Thanks RoyBoy Forgot to add the ecu shows 154 hours.
Blue smoke after starting
ÂÂÂÂÂÂÂÂÂÂÂÂÂ
