Ok question on the timing. On the fly wheel their are 4 tdc marks tdc1 tdc2 tdc3 and 4 question is in the manuel says to have the mark lined up with tdc1 at 5 + 1 deg ( at Idal) on my eng it is at tdc2 at 5 + 1 deg. Is this right or even ok.
1986 yam 115 v 4 timming marks
when the upper stbd(#1) piston is at TDC then the TDC marks with the BTDC and ATDC scale should be at TDC.
idle timing should be at 5* ATDC,carb pickup timing should be 4* ATDC and wot timing should be at 25* BTDC.
note the difference of ATDC and BTDC.
if the scale does not line up with the physical piston location ethier the pointer is off or the flywheel key is sheared.
ÂÂÂÂÂÂÂÂÂÂÂÂÂÂÂ
