I have no fire to the coils. I checked the bus bar that feeds each coil with a 12 volt tester, it had no power any where on the bar. I then checked the control unit located just below the bus bar it has a yellow, cream, brown and black wire all going to the bus bar and a pink wire coming from the wire harness, none of them have power. I thought of running a jumper to the pink wire thinking that it should be the power feed but I was afraid I might fry something. Any help you can give I'm about to pull out what little hair I have left?
Yamaha 175 hp Ignition Trouble
