oil line between remote and engine tank
  • oil line between remote and engine tank
    i had a crack in the oil line running from remote tank to the engine tank. I've repaired the line. Do i now need to bleed the system, or will it bleed itself when oil is transferred to the engine tank before being pumped to each cylinder? i'm thinking not, but want to be absolutely sure.
    You did not list the model motor you are referring to, however the oil pump has a bleed screw on it and should be opened till oil flows out to bleed the system anytime you remove any oil lines.
      model is 115TLRT (i think that's a 1995).
        the pump is gravity fed and then the main tank will just vent the air
          thanks jb123. from looking at the injection system parts diagram, i assumed it would and wanted some reassurance.
